evm1024
PM-ed ya
The power supply should not be too hard....
+- 15 are fused at 4 amps each
+ 48 at 2A
+6 at 4 amp and it is shared with the 11VAC
+-18 are fused at 2A
--Ethan
The +- 15 feed the majority of the opamps inthe board with the +-18 feeding the output stages. This being a +4dBm the higher voltage is needed. The balanced out max is speced at +28 dBm (19.5V). I would guess a little more headroom and more isolation. Output does not get fed back into a gain stage through the PS rails.
the total power is speced at 70 watts.
The 11 VAC is novel in that it feeds 2 meter lamps in series.
+ 48 at 2A
--Ethan
