You can get them from Berhi's website, but they are not cheap- the one I needed would have cost about $40.
If you need one because one of the pins inside it has broken off (that was my problem,) you can cut a straight pin to the proper length (trial and error) and insert it into the proper hole of the female plug on the board- the head of the pin will make contact with the small piece of metal left over from the broken pin. Once you get the length right, it actually works quite well.
