wheelema
Boner-obo
I mean, I'm stuck in hospital bed, and maybe, just maybe, this will help somebody.
The eternal debate between IBM PC compat and Apple Macintosh... One More Time!
I spec'd out the HOTTEST computer I could using the mwave.com website. This baby uses the HOTTEST Intel processor, the HOTTEST Asus motherboard, and the HOTTEST OCZ memory (4GB). I popped a super nice Sony DVD-RW and two Western Digital 10,000 RPM hard disk drives in. I spec'd out TWO of the HOTTEST consumer video cards, the nVidia 7950GX2. All of this is would go into a 4u rack mounted - 120mm fans up the ASS - MONSTER of case by i-Star, and be powered by an ePower 900 watt power supply. Wireless keyboard, mouse, and Windows XP Pro included.
Here are the details...
AND IN THE OPPOSING CORNER...
The FABLED Apple Macintosh PRO!!!
This monster has TWO 3Ghz Intel Xeon processors, 4GB of memory. It features the FABLED SuperDrive!!!, and uses a 160GB AND a 500GB hard disk drive (both at 7,200 RPM). It uses TWO nVidia GeForce 7300 GT video cards with a WHOPPING 512K EACH. All of this is packed into the stylish Mac Pro case. Wireless keyboard, mouse, and Mac OS included.
... AND NOW FOR THE BOTTOM LINE!!!
IBM PC Compat...$4,338
Apple Mac Pro....$4,517
CAN YOU BELIEVE IT FOLKS!!??!!??
For LESS than the cost of the FABLED, the heretofore UNDEFEATED (at least in the fevered dreams of Macintosh Nazis) Mac Pro you can get a SCREAMING bleeding edge MONSTER of a DAW.
AND HERE IS THE REAL KICKER!!!
If this shit scares you, Mwave will build the IBM Compat for you for only $75! Your friends never need to know you can't hold a freaking screwdriver!!!
... and by the bye... I spec'd out the Mac using educational pricing!!!
Well! I feel better!
Whoo Ra!!
- INTEL CORE 2 EXTREME X6800 (BX80557X6800) 2.93GhZ EM64T DUAL CORE W/2MB CACHE 1066MHZ LGA775-PIN RETAIL BOXED W/COOLING FAN (3 YEARS WARRANTY) $995
- OCZ OCZ2G10002GK 4GB KIT (1GB x 4) PC2-8000 1066MHZ 5-6-6-15 240-PIN DDR2 DIMM W/HEAT SPREADER $639.86
- ASUS P5W DH DELUXE INTEL 975X CHIPSET SERIAL ATA300 ATX FORM FACTOR 2xPCI-E(X16)/2xPCI-E(X1)/3xPCI/4xDDR2 W/SATA2 RAID,DUAL LAN(Gb),1394A,USB 2.0 & AUDIO (CPU TYPE:INTEL - SOCKET 775) $256.80
- I STAR D-400L STORM SERIES 4U (BLACK) RACKMOUNT NO POWER SUPPLY 7x5.25" 1x3.5" 1x3.5"(hidden) W/ FRONT USB 2.0 PORT, 120mm CASE FAN x 3 & 80mm CASE FAN x 1 *SLIDING RAIL NOT INCLUDED! $190
- EPOWER TG-900-U95 900W TURBOJET SERIES EPS 12V SLI CERTIFIED & RoHS COMPLIANT POWER SUPPLY FOR ATX CASES $349.00
- SONY DRU820A 16x8x16x/DVD+RW 16x6x16x/DVD-RW 8x/DVD+R DL 4x/DVD+R DL 48x32x48x/CD-RW EIDE INTERNAL W/SW (Retail) $69.94
- (x2) WD 150GB WD1500AHFD SATA150 10,000RPM 16MB Digital Raptor X $275.00 each, both for $550.00
- MICROSOFT B7T-00001 WIRELESS LASER DESKTOP 6000 KEYBOARD & MOUSE COMBO PS2/USB $49.90
- ZALMAN CNPS9500 LED-CU COPPER BASE CPU COOLING FAN FOR AMD (SOCKET 754/939/940) AND INTEL (SOCKET 478/775) PROCESSOR W/3 PIN CONNECTOR $57
- MICROSOFT WINDOWS XP PROFESSIONAL W/SP2 #E85-04135(DSP/OEM) $129.90
- (x2) EVGA 01G-P2-N592-AX GEFORCE 7950GX2 1GB DDR3 PCI-E W/HDTV & DVI $519.90 each, two for $1,039.80
- Mac Pro Z0D8
- Bluetooth 2.0+EDR module
- Apple Wireless Keyboard and Apple wireless Mighty Mouse - U.S. English
- 500GB 7200-rpm Serial ATA 3Gb/s
- One 16x SuperDrive
- Accessory kit
- Two 3GHz Dual-Core Intel Xeon
- 160GB 7200-rpm Serial ATA 3Gb/s
- 4GB (4 x 1GB)
- Mac OS X - U.S. English
- 2 x NVIDIA GeForce 7300 GT 256MB
Whoo Ra!!
