M
mixaholic
i heard that it was better to use a wide Q(bandwidth) when boosting and use a narrow Q when cutting. Does anyone use this method? what Q numbers fall into the category of wide and narrow?
mixaholic said:i heard that it was better to use a wide Q(bandwidth) when boosting and use a narrow Q when cutting. Does anyone use this method? what Q numbers fall into the category of wide and narrow?
Probably if a good engineer were to add up all his eq settings over time and tally them by category, they'd probably find that a large number of their cuts were narrow Q to get rid of specific offending frequencies, and that a large number of their boosts were gentle wide Q bumps. So there may be a small kernal of reality inside of that broad generalization, but by making into that broad generalization, one is distorting truth into false myth and bad technique.mixaholic said:i heard that it was better to use a wide Q(bandwidth) when boosting and use a narrow Q when cutting. Does anyone use this method? what Q numbers fall into the category of wide and narrow?
RAMI said:Possibly, but I rarely boost, so I can't say for sure.
But common sense would tell me that there shouldn't be a rule saying "wide Q for boosting and narrow Q for cutting"...Why? Every situation calls for it's own aplication.
Put the Sticky up.SouthSIDE Glen said:... but by making into that broad generalization, one is distorting truth into false myth and bad technique.
G.
