I have a choice to make here....
  • Thread starter Thread starter xandro
X
xandro
here's the deal...
I seen a used (looks like it's in pretty good shape, cosmetically anyways) Yahama MT-4X 4 track recorder at a local pawn shop for $129
or I could plunk down $250 and get a brand-new Tascam 424-MkII (the newest one they have out)
I don't know how good the Yahama deck actually is, or if it records in the same manner (i.e. all recording is to one-side of a type 2 cassette). I noticed the Yahama had two speeds (4.8 and 9.6 ips??) while the Tascam has (3.75 and 7.5 ips)
anybody have any more detailed info on the Yahama?? I tried scouting around different spots via Google but no real details on it.
and also judging from the two...which one would you grab??? would you go with the deal? or would you go brand-new??
thanks for your replies
The yamaha is the same speed they just list it in I think it is centimeters instead of inches.
If money is not a big deal then I would go with a new tascam.
Plus the tascam has a couple of xlr inputs for your mics I think where the Yamaha does not and that would mean unless all of your mics have 1/4 inch plugs on them you would need to buy adaptors so there you will be spending more money on a used recorder,
I'm with Herm on this one. Get the brand new TASCAM MK-III.
Yes, well,... I think you mean the new 414mkII, and it's a fine little machine,...
but the Yamaha has a somewhat better equipped mixer than the Tascam. It's kinda like comparing apples & oranges,... but what I can tell offhand is that the Yamaha has a better EQ section, & a slightly better 4-group assign matrix, vs. the Tascams 1/2 in buss mode and 1-4 in direct mode. Considering there's only 4-channels and 4-tracks, that's not a huge difference.
Anyway, the MT4X looks like a worthy machine, if you can find one in v-good condition that runs perfectly. The Tascam 414mkII is a good machine, and although buying brand new recorders is a great thing, I've been getting tremendous value in 414mkII deals fo $65-$85 a pop, used on the Ebay scene. I'll tell'ya,... the 414mkII is a tremendous machine for avg. $75, if u can find it.
In many respects, the MT4X is more roughly equivalent to the Tascam 424mkII than the 414mkII. However, the 424mkII is a little better equipped than the Tascam MT4X.
If I had $150 to blow on a used Yamaha, or $250 to blow on a new Tascam, I'd probably be more inclined to purchase a used 424mkII (~$100) or a like-new 424mkIII (~$175), and call it a day. That, or the above mentioned used 414mkII for $75.
The Yamaha looks good, but I'd try to get them down to $100,... the comparable worth of the used 424mkII.
http://www.yamaha.com/yamahavgn/CDA...tail/0,,CNTID%3D125%26CNTYP%3DPRODUCT,00.html
http://www2.yamaha.co.jp/manual/pdf/pa/english/recorders/MT4XE.pdf
Variable Microphone/ Line Gain on Every Channel
The MT4X offers continuously variable gain adjustment from microphone to line level on all four channels so you can achieve perfect matching with just about any source.
3-band Channel EQ
Three-band equalization controls on each channel, incorporating shelving high and low bands and a peaking mid band that offers precise control over the critical midrange frequencies at which vocals and many other lead instruments are centered. You can individually modify the sound of each signal while recording the original tracks, and again when mixing down for extensive tonal control.
Dual Auxiliary Sends and Assignable Stereo Returns
The MT4X gives you two for extra signal processing flexibility. Instead of just one effect unit, your MT4X can be connected to two and the channel signals routed to either as required- without the need to re-patch whenever you want to change effects. Two-way Aux controls on each channel let you send the channel signal to either of two external signal processors, and the output from these can be individually fed back the MT4X's two stereo auxiliary returns.
Dual Auxiliary Sends and Assignable Stero Returns cont.
Both Aux returns feature level controls and track assignment switches so the left- and right- channel processed signal can be mixed into tracks 1 and/or 3 and 2 and/or 4, respectively.
4-track Assignment and Panning With Independent Stereo Buss
Each mixer channel has two group assign switches and a pan pot that allow the channel signal to be assigned individually to any of the recorder's four tracks or to either or both stereo pairs (tracks 1-2 and/or 3-4) with continuous stereo pan control. In addition to the four track "busses", the MT4X has a separate stereo buss that receives its signal directly from the channel pan pots.
Precision Two-speed Transport with pitch Control
A precision 2-speed transport gives you a choice of standard 4.8 cm/sec tape speed or a high 9.5 cm/ sec speed. The transport is also designed specifically for high-bias (Type II) tape. A +/-10% pitch control that lets you vary the playback speed to match the pitch of the recorded sound to other instruments, or change the overall playback length of the recording.
Punch-in/Punch-out Recording with Auto Punch I/O Function
"Punch-in" and "punch out" to selectively replace a segment of a previously recorded track. The MT4X gives you three punch-in/out options - you can punch in and out manually using the panel controls, using an optional FC5 Footswitch plugged into the Pinch I/O jack, or automatically using the sophisticated Auto Punch I/O function.
3-point Auto-locator
The MT4X lets you locate counter "0000" or two other programmable points at the touch of a button.
Direct Tape Outputs
Independent Tape outputs for each recorder track permit direct transfer of the MT4X's four tracks to a second multitrack recorder, or the tracks can be directly fed to an external mixing console.
Built-in Noise Reduction with "Sync" Mode for MIDI Synchronization
A built in dbx noise reduction system effectively reduces tape noise to below the threshold of audibility. The dbx system can be switched off if not required, and has a "sync" mode in which dbx is not applied to track 4 so that track can be used to record a Midi synchronization.
Central Mult-function Display
This attractive two-color fluorescent panel makes operation easier and more efficient by concentrating all the information you need in a single display. All operating modes and signal levels can be read at a glance so you can grasp the overall status of the entire MT4X system without having to scan the panel for separate displays and indicators.
SEE: YAMAHA MT4X
Tascam 414mkII:...........
http://www.tascam.com/Products/414mkII.html
http://www.tascam.com/Products/414mkII/Porta_414mkII_manual.pdf
For you or as a gift. The new 414mkII Portastudio is ideal for newcomers or those experienced in multitrack recording, packing high-end features into a convenient, compact and economical package. A high-speed transport, combined with Hi & Low EQ and dbx noise reduction means great sound. For convenience, there are also 2 XLR microphone inputs, and a 1/4" HiZ guitar input. Use it for demos, as a portable sketch pad, or for practicing recording techniques.
4 track recorder with 8 input mixer
4 mic/line input channels, 2 stereo inputs
2 XLR mic inputs
HiZ guitar input
2 effect sends
2 band EQ on each channel
3 3/4 ips high tape speed
dbx noise reduction
Optional RC-30P punch-in pedal
I thought he meant the 424mkIII. ;)
Anyway, haven't read your entire reply, Dave, but BRAVO!!
Tascam 424mkII:...
........................... :eek: ;)
The Tascam 424 MKII Portastudio is a 4-track "Multitrack Master" cassette tape recorder and a full-function mixer with 8 inputs/stereo outputs combined into a single workstation. The 424 MKII records on readily available standard (Philips) Compact Cassette tape, high bias Type II. The recorder has 4 tracks while the mixer has a stereo output; however, using the DIRECT feature you can record on any or all of the 4 tracks at one time. The 424 MKII's dbx Noise Reduction virtually eliminates unwanted tape noise. A special SYNC feature turns off the dbx on track 4 separately, making it possible to record and play back the MIDI sync tones or SMPTE/EBU time code without being affected by the dbx encode/decode. This ensures that the sync tones/code are recorded and played back without unnecessary processing. With proper operating techniques, it is not necessary to leave a guard band between music and sync tone tracks because of the low crosstalk of the TASCAM heads.
4-track recorder with 8-input mixer (4 mono and 2 stereo) 3-band EQ with sweepable mid 2 tape speeds, logic-controlled transport, and 2 locate points Return To Zero function Sync In/Out jack, and tape pitch control Balanced XLR inputs allow for high-quality low-impedance microphones Auto punch-in/out with rehearsal 2 dedicated AUX sends, one assignable to CUE for headphone mix 4-track simultaneous recording For the musician looking to take the next step up in multitrack recording, the 424 MKII is a premium Portastudio. Superior audio quality, balanced XLR inputs, enhanced equalization, and a big-studio style AUX section make this the ultimate compact 4-track Portastudio. It also has Tape Direct Outs for integration with external mixers.
Tascam 424mkIII:...
..................... :eek: :confused: ;)
http://www.tascam.com/Products/424mkIII.html
http://www.tascam.com/Products/424mkIII/Porta_424mkIII_manual.pdf
The 424mkIII is TASCAM's finest cassette four track. Its advanced feature set offers something for everyone. The 2 independent auxiliaries mean you can add two separate effects to the same channel... not something many of our competitors can do. The 3 band sweepable mid band EQ gives you the flexibility to focus on the sweet spot of the sound to help give it a little more life. The 4 XLR mic preamps keep your inputs quieter, and will save you from the hassles of finding the XLR to 1/4" transformers. The expert will appreciate these advanced features. The novice can grow into them, and improve their skills with time.
4 XLR mic preamps
6 channel strips & 1 stereo input
3 band EQ with sweepable mid on each channel
2 effect sends
3 3/4 ips high tape speed, and 1 7/8 ips normal speed
dbx noise reduction
Electronic transport for better tape handling
Individual track outputs
Separate I/O for mixdown deck connection & monitoring
I swear by my Yamaha MT100 - a few generations earlier but build like a tank & GOOD sounding - with quite good preamps too.
I use it to record basic 4 tracks before uploading to comp. & even add extra tracks & upload then nudge. Mind you I'm still learning with the nudge thing.
The mixewr is good, the DBX is good (ta dave), the thing is easy to clean & maintain. Etc Etc Etc.
Cheers
rayC
thanks for the replies guys...
and yes, I did mean the Tascam 414...heh
I had a total brain freeze when I was trying to remember the model number.
I was actually thinking about talking the pawn shop guy down to about $100 or $110 because I didn't see an instruction booklet for it at all, maybe he has it behind the counter. But if there's no instruction booklet, I'm not paying $129 for it, that's for sure.
Money is a bit of an issue at the present time, I figure I could use this to get my feet wet in the world of 4 track recording and then step up to the Tascam at a later date, that's what my thinking was anyways.
again thanks for the replies and the information supplied on both machines, it's very helpful and appreciated.
have a good weekend, gents
I just realized shortly after I typed out that last reply that there was a link to a PDF file with the manual on it.
thanks A.R.P!!
I'll still see if I can talk him down, though
