kojdogg said:
here are some questions that can also help guide the answers you'll get:
do you have a decent computer-- what are the specs?
do you have any mics or other gear to start with?
if you're recording bands, how many tracks (parts) will you need to record at once. keep in mind that people generally use multiple mics (anywhere from 1-10+) on a drum kit-- each mics counts as a separate track.
what kind of acoustic space is your studio going to have? concrete w/ 90 angles generally is not good.
what will be the purpose of these recordings?
I think I have a decent comp. Man it's been a while since I've looked at my specs, ha.
Comp Specs AMD Athlon XP 3200+(not sure the ghz speed. it has been a while) 512mb of ram, I'm hoping to upgrade to 1 if not 2 gb of ram. 160gb hard drive, Geforce FX 5500 and umm.. Yeah, I think that's all really. One drive to burn discs with.
Edit: And oh yeah, I'll be using Cubase LE for a recording program. It comes with the Alesis mixer.
Gear to start withI have an ALesis 16 channel firewire mixer.(yes my comp has a firewire port) I have m-audio studiophile monitors with the sub included. Then I have a couple sm-57's and a vocal mic is on the way from a friend in town. I have cables for those and such. I'm looking into drum mics as well. Then I have all the amps and guitars and drums to be miced. Yeah, I'm not a COMPLETE noob, just a noob to what goes on the rack and such, or rather what the things in the rack do. I'm on a tight budget, that's what I don't have much, and yeah. I'm looking into more equipment, that's why I'm asking about this stuff. Umm...me and my dad built the studio, it's not concrete, it's not a square, we have an angled ceiling for acoustics, we've done research on the internet about that. It's nothing fancy, I'm not planning on doing many live recordings in there, but If the opportunity arises, I think it should work out decently. I have another mixer that we're using specifically for drum mics if we run out of tracks on the main mixer. Purpose of the recordings will be to make some albums for local bands. I won't make the cd's myself obviously, or master them. But yeah, just record. I think that answers your questions, thanks for the help
-Elliot
Robert D said:
Here's a quickie primer........
By "The rack", you would be referring to a 19" rack mount cabinet, who's purpose is to house "outboard" equipment. Outboard refers to the fact that these items are not part of the desk (mixer) or the recorder. Outboard gear can be anything from effects processors to EQs, preamps, power amps, compressors, limiters, gates, midi routers, crossovers, power conditioners, etc.
The rackmount cabinet has a pair of vertical rails with a bunch of tapped holes, the spacing of which is consistant with the industry standard 19" so that outboard gear with rack mount ears can be bolted right in.
hope that helps.
Alright, thanks man. Is it an easy thing to make your own rack? My dad is a carpenter so he knows what he's doing.Yeah, I know about what kind of stuff goes on the rack a little, but what I really need help with is what all the stuff does, and which equipment makes the biggest difference.
-Elliot
MOFO Pro said:
Hate to get all "Gloom & Doom" on you... but...
You should have started your research BEFORE building your studio... It's the first... and most critical piece of your signal chain...
Plenty of sites for studio design and tips on the web... you may want to take a peek...
We have researched all sorts of stuff on the building itself. We are almost done with it and right now the sound absolutely dies when in there. It's awesome
I know how it seems, but yeah, I'm just wondering about equipment. Thanks for the help though
-Elliot
