1
\/\/1|_|_
What's the difference between bits. like 16bit and 24 bit..etc? what results will recording in different ones yield
thanks
thanks
TelePaul said:doesnt 24 bit take up more hard drive space?
Yes, the more information you have, the mose space it takes up.TelePaul said:doesnt 24 bit take up more hard drive space?
How does a high sample rate get you a lower latency?OhSh1rt said:I always record at the highest sample rate possible just to get the lowest latency.-jeffrey
Farview said:How does a high sample rate get you a lower latency?
What are you using? I've never seen anything get 0ms latency without having a hardware bypass. Are you sure that you are monitoring through the computer?OhSh1rt said:96KHz gives me 0ms latency with a low buffer unlike 44.1KHz which won't give 0ms at the same buffer.
-jeffrey
Farview said:What are you using? I've never seen anything get 0ms latency without having a hardware bypass. Are you sure that you are monitoring through the computer?
You are confused about this. You may be monitoring through your soundcard but you are bypassing the software which is what Farview is correctly calling direct monitoring using a hardware bypass.OhSh1rt said:ProTools with a Delta 66, the drivers claim to have 0ms with my current settings, sounds impossible though
And yes, I drive the monitors through the out on the card which is fed from protools.
-jeffrey
More bit depth gives you more headroom only because you can record at lower volumes while still having more resolution than the final product. At 24 bit, your recording levels can peak at -48dbfs and still have more resolution than the CD the music will eventually end up on.dementedchord said:personally i think the bit depth buessiness is misunderstood..... while it does give more headroom with internal math(larger accumulator) in terms of gathering initial samples i have my doubts..... the front end you use has x amount of voltage swing its capable of and changing the bit depth wont give you more..... so bit depth here is how many discrete slices of that voltage can we create...hence the idea of resolution.... remember every time you ad a single bit you double the available resolution... so 8 bits more data ads 2-8th power or 256 x's the resolution....
