R
raypat223
hi
i am looking to sell a mixer and PA speaker ...... this is my first post, not sure if I have broken any rules yet...
the mixer specs :
The mackie pro efx 12 professional 12 track mixer is three months old and has been barely used:
here are the specs:
Professional 12-channel Compact Mixer with onboard effects and USB I/O
6 low-noise, high-headroom Mackie mic preamps with easy LED metering
32-bit RMFX processor with 16 "Gig-Ready" reverbs, choruses and delays
Precision 7-band graphic EQ for tuning Mains or Monitors
USB I/O for recording shows and music playback via Mac or PC
4 full stereo channels plus extra stereo return for keyboards, external effects or stereo playback devices
60mm faders for input channels, returns and Main/Monitor masters
3-band active EQ (80Hz, 2.5kHz and 12kHz) on all channels
Hi-Z input for direct connection of guitar, bass and other instruments
Insert, 100Hz low cut filter, and 48V phantom power on all mic channels
Stereo RCA tape I/O with input level control
Headphone output with separate rotary level control
Balanced XLR and balanced/unbalanced ¼-inch Main outputs
FX mute with remote control via footswitch
Break switch mutes all channels for music playback between sets
Built-like-a-tank steel chassis with rugged, yet stylish ABS sidecheeks
"Planet Earth" switching power supply for worldwide use
Includes Tracktion 3 Music Production Software for Mac or PC
the QTX Sound 800 watt speaker specs:
the QTX SOUND 800 watt PA speaker is also three months old and this has never been used an is bran new.
the QTX SOUND 800 watt specs:
QTX QRC15A features include:
Titanium compression horn driver
PTC driver protection
Mic/line inputs with volume controls
Integral handles
Tone controls
35mm top-hat fitting
Power supply - 230Vac, 50Hz (IEC)
HF driver - Titanium dome compression unit 2.5cm (1")
HF dispersion - 90° x 40°
Inputs - Mic, line
Main driver 38cm (15")
Power RMS 350W
Power peak 700W
Frequency response 35Hz - 20kHz
Sensitivity 101dB
Crossover frequency 2.5kHz
Dimensions 730 x 450 x 380mm
Weight 22kg
the mixer bran new cost me £179 three months ago and I have hardly used it, it has never been out of the house or used anywhere...
the Pa speaker cost me £180, never bee touched, still in box as new, yes I have listened to it obviously but it has remained in the box since the first day I bought it
ii ma unable to load up pics at the moment for some technical reason but i can send pics or and show the items on webcam, or better still come to view them.
hope this post wasnt too long
I live in the north london area if anyone is interested
the mixer specs :
here are the specs:
Integral handles
Tone controls
Inputs - Mic, line
Power RMS 350W
Power peak 700W
Sensitivity 101dB
Weight 22kg
