amonte
Hi,
I am having some real problems with the Midiman DMAN 2044 sound card. I have contacted tech support on several occasions and the clearly do not want to help. They simply ignore my messages. So, once again, I need some help - here are the specifics:
- Pentium 233 MHZ
- 13.5 GB Hard Drive, 86% empty
- 64 MB or RAM
- DMAN 2044 Card
- SoundBlaster AWE 64 Gold
- Cakewalk Professional 7
- NTrack Studio
- Windows 98
This computer has been optimized for digital audio recording, according to the documents posted on optimization for recording. If you would like specifics please let me know.
The problem is that whenever I play back the audio through my DMAN, it sounds like it is being clipped, goes out of phase (even though the tracks were not recorded at the same time), has static, and overall really just sounds terrible. At some points it reaches unlistenable states. But I have found that when I stop the playback, then start it again, it cleans up, only to go bad again about 5 seconds later. The problem occurs on a decling scale - so the audio starts clean, then gets progressively worse as playback continues. This even occurs during the recording phase, so to get past this, I have been using my AWE card for the playback and my DMAN for recording. THis has worked fine so far, but I am concerned about latency issues between the two cards.
Please keep in mind the following when you post a reply:
1. The hard drive has been partitioned
2. The jumpers on the DMAN 2044 are pulled OFF - so they card is set to +4dB instead of -1dB.
3. I am sending the outs of the DMAN card into a small foxtex mixer, which is hooked up to a set of PC speakers. I don't believe the issue is with the mixer or speakers, since the SB plays back fine.
4. I have already tried reinstalling the card, moving it to a new PCI slot and reinstalling the drivers.
Any help would be greatly appreciated.
Thanks,
Jer
- Pentium 233 MHZ
- 64 MB or RAM
- DMAN 2044 Card
- NTrack Studio
- Windows 98
Thanks,
Jer
