Steve, thanks again for all the useful information.
When I say my target is an STC of 60, I don't expect to achieve 60dB of noise reduction; I know thats a theoretical number, achieved under optimum conditions.
My main areas of concern are the following:
The Control Room
This room is, as near as I can get it, in complete isolation.
It shares no common walls with any part of the structure, and no common walls with any other room.
It does, however, share a common slab with the rest of the structure.
If my exterior walls achieve even 50 dB of noise reduction, and I get another 50 from the CR itself, I should be creeping towards that target of 60.
But those are the walls. There's weak points in every design: Doors.
If I have 2 sliders that will achieve 45 dB of noise reduction each, then I'll never approach that target of 60.
The Drum Room
Obviously low frequency response is going to be the culprit here.
Again, no common walls with the other rooms, but unless you're building a bank vault, some noise is going to escape the structure.
I'm not too worried about sound escaping the structure, I just don't want too much bleed into the live room.
Double walls with a varying 8" - 12" of separation and the Rockwool-triple layer system is my solution.
Once more; double sliders - the weak point.
The Mechanical Room
I'll have, I guess what's refered to as a split system for HVAC; The A/C compressor is outside, and the air handler is inside.
Double walls, and a separate ceiling is my solution here.
Of course my bids are for over-sized ducting, no common ducts from room to room, a 2 speed 'squirrel cage" fan system, and rigid ducts for the returns.
The 2 speed fan allows you to "turn it down" with out turning it off, if need be. It seemed like a good solution from a local company experienced in studio HVAC construction.
Those are the major areas of concern for me.
Again, I'm not too worried about sound escaping.
I don't live by an airport or a highway, but I want a quiet interior for recording and a quieter one for mixing.
My main market strategy is going to be classical music, and jazz.
I expect, and hope, to do the odd rock-metal band, but that's NOT my market focus.
Additionally, I've had some success (locally) at composing for independent film, and hope to build on that.
Moreover, none of the construction techniques I have seen deal with the fact that an attic space must be vented to the outside, and don't discuss the fact that the eaves have gaping vents in them! So much for the outside walls!
I'm just gladfind a happy medium between what building codes allow, and what recording studios require.
In the end, when its all said and done, it'll be 1000 times better than what I have now!
