cephus
Slow Children Playing
Since I really don't have any physical way to lay out the position of the pivots for my floyd rose, I can put it pretty much put it where I want within a range. I was thinking that, as a middle child, the saddles should all try to be towards the middle of their range of motion to accomodate future intonation ajustment. Well, I generally get them where they are supposed to be and use the same brand of strings, so they don't change very much if at all. I marked where the high and low E's saddles line up for the standard strat bridge on there now. I can guesstimate that when intonated, the floyd saddles should be close to the same place.
It just occurred to me that the trem may have a mechanical advantage at one end of the travel versus the other. Like maybe if the saddle is all the way forward, it doesn't arc as far when you push down the bar. Maybe tuning stability would be better at that end, or tone worse.
I think I should drill the posts so that the saddles would be slightly rear of the mid-point to give greater range of motion and greater potential for spaghetti strings and sirens and motorcycles.
Any other theories?
Any other theories?
