R
rothy
Hello all - I am looking for your wisdom yet again...
I am setting up a new studio in my home and am having trouble silencing the A/C vents supplying cold air to the room. I live in Phoenix, AZ and simply turning off the A/C would not be an option... the A/C runs even when the thermostat is set at 78 - I even have a high-efficeincy Trane package heat pump - but it's 120 flippin' degrees outside.
I am just looking for low-cost DIY solutions, as I am not ready to build a room within a room or construct an iso booth. My room is about 20'x20', and there is one 20"x20" return air (sucking vent) and 2 12"x12" registers (blowing vents). All vents are in the ceiling, one of which is directly above my recording/mixing space. The room is also very well insulated and isolated from the rest of the house - this means no outside noise is getting in, but when I close the door to the room, it creates a very "tight" space, and the vents blow even harder. I have also installed some corner traps and other wall treatments - no egg crates.
My first idea is to create a box from acoustics foam (13"x13"x6") that can be placed over the vents, attaching to the ceiling with velcro. I would place holes on the sides that would still allow air to flow, just directed up/sideways instead of right DOWN into my mics. I won't know if this works until I try it I guess.
Has anyone else had this problem, or been able to overcome this with a specialty vent or something?
Thanks!!
Thanks!!
