Hum when playing 3.5 disk in computer
  • Thread starter Thread starter gospelmusic1925
G
gospelmusic1925
I have a Yamaha PSR 740 and I record music on 3.5' disk and play and transfer the music to my hard drive. Recently a friend upgraded my computer and since then when I play my disk there is a heavy hum in the back ground. Now when I play a recording that does not have the keyboard ACMP recorded there is no hum.
Any help would be much appreciated
Ed
The only thing I can think of is that your keyboard wasn't grounded at the power source.
Or, an unshielded cable was near a transformer or something.
Have you recorded on other disks since your upgrade? Is this the only disk that makes the hum?
Did you upgrade your sound card drivers? When you say "Up graded your computer", do you mean software or hardware?
Did your friend pop the hood on your computer box? If so, open your computer and check the cables to your floppy drive.
If your disks play ok when there is no keyboard being played, I'd say to begin with the keyboard.
Check the receptical it is pluged into for proper ground. Maybe your dad has a ground checker you can use.
Check the plug in cable connections from your keyboard for crud or that green stuff that builds up on some during the wet season.
Check your keyboard cables for a bad kink that may have a broken wire.
Repost and let us know. If none of these ideas help, someone will come along with more.
Good luck.
After doing a lot of checking it seems that of the 163 styles for backk up music that #79 Gypsy Swing is the only one where I get the the hum...so I guess this is a keyboard problem...
Thanks for your suggestions.
Ed
