soundchaser59
Reluctant Commander
I opened up my HR16 and my SR16 tonight, thinking since they are 18 and 12 years old, respectively, they could probably use replacement batteries.
DAAAAD GUMMMMM YOU Alesis for putting soldered in batteries in your gear. (That fact alone will stop me from EVER buying another piece of gear with that name on it!) Nothing like a company acting friendly and smiling wide while they take your $120 bucks ($20 for the battery and $100 flat rate repair fee) just to change a 50 cent battery for you because they soldered it in place.
Well, I'm doing an end around on Alesis. I found a place at www.batterystore.com where I am able to buy the
Tadiran TL5101 3.6v lithium 1/2 AA "P" terminal battery for the HR16 (has the wire leads attached on each end so it can be soldered to the PCB)
and the
Panasonic CR2325 3v 3-pin Horizontal mount battery for the SR16 (the solder pins are spot welded to the battery - same as BR2325)
each one for $5 bucks! FIVE BUCKS! I can save over $100 bucks just by doing a google search and a bit of soldering.
Shame on Alesis for making their gear so unfriendly on the inside!
Hope you guys can use this, I know there are at least a handful of people here who own one of these two drum machines. - SC
and the
