HR Cover Challenge - fenderlikingood's song
  • Thread starter Thread starter B.SABBATH
This is extremely good. I noticed some changes in your mixing in this one. Your using a bigger horizon kinda like the "large music hall/theatre sound", the kick drum has the resonant frq`s pulled back and the Meat pushed up more and has bettter impact without crowding. A brighter mix on vocals and guitar. Seems like a different reverb than normal , has more natural sounding air in it. Ultra clean and not crowding anywhere....
awesome vocals on this one delivery wise...........powerful mix here.............i love the screams
I feel sooooooo ........... inadequate! We are not worthy! Sam, I can't believe what you did with this. The mix just rocks!
Twist
i think this is my favorite of your tunes sam. i LOVE THE SCREAMING. i would like to hear your reply to chrisharris' question though. wanna know more about it, although i'm pretty sure my throat would never survive something like that!
The reason I picked this song was this... fender had been around for awhile commenting on peoples tunes, but never posting anything himself.. When I finally heard something from him, I thought it was sooo insane and raw, I had to cover it! Even if there wasn't a challenge I probably would have covered it..
fenderlikingood - hey rick, your response was more than I hoped for.. I'm glad you like it! :D I think the only lyric alteration was when I added 'God' to the line, "up so high like I had wings." That made it "up so high like God had given me wings." It helped with the freestyle flow I was going for..
About you selling your gear, I KNOW EXACTLY WHAT THAT'S LIKE.. I have had to sell all my gear SEVERAL TIMES just to pay bills when work was slow.. No joke! Don't sweat it because it's just stuff that can be bought again.. Sometimes even cheaper.. There was a time when all I had was an acoustic guitar, and a rubber pad for drum practicing.. I appreciated my gear so much more when I built it back up again, but if something happens tomorrow, I'll sell my gear again if I have to.. It's like a boat that takes on some water.. Sometimes you just have to throw some dead weight overboard and go back for it later.. You can always get stuff again.. thanks again for making me record something I wouldn't have other wise! mixmkr said this was one of my best!! :D
Kramer - The drums were done in Fruity Loops, and then imported into Acid.. I usually make up one measure for each part, and then put it into song format in acid.. It helps to have good samples.. I think Fruity is the way to go if your not a good programmer.. It is by far the easiest drum programming tool I have ever used.. If you got it, you could take all the samples from your SR-16, and turn them into little wave files, and then be able to use them easily in Fruity Loops.. There are some good SR-16 sounds I have sampled already.. The key to making usable samples is to make sure you cut off all the dead space before it.. If you left any blank space before the snare hit for example, it is going to be all out of whack when you try to use them with the sequencer.. It takes some time to make your own samples, but once your done, it's well worth it to be able to use those sounds in Fruity.. Acid comes in very handy too! I highly reccomend both..
Track Rat - check out Kramers reply.. If there is any improvement, it's because of the board.. I remember listening to that thing you did with rats, and I learned something from hearing that.. I try to never drown out the drums anymore..
chrisharris said:
how do you get the sound on the scream? That hollowed out, death type scream...it's more than reverb, lol. I need a good Prodigy-type scream for something I'm working on, and I can't figure out how to get that sound.
[edit] Specifically, @ 1:18
I added extra distortion and delay to the vocal sound at the time I was laying it down.. That's the reason why I print effects.. Sometimes you need to use the effect to help with the performance.. In this case, I got the sound first, and then did the screaming after I heard how it would sound.. I used to scream a lot in my tunes.. Distortion and delay.. I don't know if this has anything to do with it, but I'm always smoking weed when I record, and I think it helps with vocals.. For some reason I always get closer to the sound I want when my throat is dry.. (cotton mouth) I rarely ever drink any liquid when I record.. It might help give me the scratchyness that adds to the screams.. I'll never make most 'marketable singer on the board,' but I may take the award for 'most inebriated.' :D
crawdad said:
do you use a 7 string AND tune it down?
I don't own a 7 string YET! :D I plan on getting one soon though.. For this song, I was playing a Hamer telecaster.. I put a Seymour Duncan hot rail in the bridge.. The sound is like night and day compared to what it was when I first got it.. I left the neck pickup stock for those solos when you switch to the neck and lower the tone knob down.. There were only 2 guitar rhythms on this.. The chain was ---- guitar----Boss Pedals-----J-Station---Blue Max compressor.. The solos were----- Pod Pro--- Blue Max compressor, and then right into the recorder.. I e.q.'d a bit.. The tuning for this was drop C#.. Normally I'll use either drop C# tuning, or B-flat, or E-flat.. I have 12's on the B-flat guitar (mexi strat), and 11's on the tele.. Even though I'm going direct, it makes a difference to record loud.. I'm actually able to get feedback from my stereo speakers when I play loud enough! :D
mixmkr - your next!! :eek: seriously though, your song is not going easy for me.. It's taking a lot of time.. I have a question for you.. I don't 'record through' a Behringer mixer, but I 'monitor' through one.. I think it's effecting what I'm hearing because the songs always have more bass on them when I hear them on the net.. Does the low end get boomy over there?
O.K. I think that does it for the questions.. Thanks again for the ears.. I had much fun doing this one..
list of homo errr, I mean list of appreciation... :)
SLuiCe -email
Stratomaster
Kramer
fenderlikingood
chrisharris
Gidge :D
Track Rat
JMarcomb - Men at Work??:eek: WTF?!!! :D
flash2ace
crawdad
mixmkr
Toki987
powderfinger
twist
erichenryus
M.Brane
THANKS!!!!!! :)
Kick ass. It gets me angry and makes me want to break stuff. Great job Fendercide and great job Samicide.
The kick drum sounds weird. Overpowering. It steals everything else when it hits (in the low frequency). You REALLY made this sound very you, you know :D Very cool version. The big drum-pounding thing is pretty powerful, but again, the kick sounds too weird to me. The snare is pretty good. Maybe you love that kick, so I won't say anything more of it :D
I love the insane sounding guitar solos. Mad professor type of stuff definitely. Hey, did you just do some rap there :D That was cool. I can't believe I enjoyed that but I did. The guitar sound is great again.
hmmmm.. I wasn't sure.. I'm having a lot of problems getting the drum levels right.. I'm always afraid of drowning them out.. Since there was some rap-ish vocal, I especially wanted it to thump, but I didn't want it to be too much.. What do you mean by weird? Did you listen to the VBR? Maybe I just made the other instruments too low? thanks Crank!
thanks for the listen JR!!! I broke something when recording this..
my new headphones.. :(
:D ...........Great cover my brutha........ Very nice arrangement and mix. .........This was a great listen. ....nice guits in it too..........
.......bust most importantly, I am with the multitudes....... Great screaming! .....Full throated screaming, yet not thin and toneless..... ....it an art as big as singing itself.
Very nice sam,
gw/5
.....and FLG, go git yer shit outta hoc man! ...youre due for a new submission:)
Nice!
Dude i love those synths...and all the whammy shit was pretty cool. I gotta hear the original yet, this was really cool. Do you use the 300 for the harmony/Doubling...it sounded really cool. Keep the good stuff coming.
Thanks for the in depth reply about the drums Sam!You know how much trouble I've been having with that.This info will help me out a lot.Im gonna try my hand at your suggestions.Thanks again man!
Holy crap...that was awesome!!!!! I listened to both versions. I think I missed FLG's 1.5 challenge. That was definitely interesting. Almost Bowie sounding in the voice.
Interesting song & well covered.
Not my genre, but after a bit I actually got into it, nice work putting it together.
Its a good thing the wife and kids didnt catch me:D .
I may have to start listening to some of this stuff, In secret of course.:cool: :cool: :cool:
nah.. I tried it a few times but it's completely fake sounding.. It will work great as an effect though.. it just doesn't work to try and use that to make an artificial harmony.. If it did, I would be using it! I will use the harmony effect when I want something spacey or ill sounding.. The basic vocal sound of it is pretty good imop.. Definitely a great buy for under 200 beans!! :eek: thanks for checking it out!
Guernica - email
Kramer - no problem man.. If you ever want to b.s. about it, drop me a p.m. anytime!
mixmkr - thanks for the confirmation!
Jagular and wafaroni - appreciate the ears guys!
thanks again to all who bothered!! :D
