To me, everything was jammed in the middle. I could hear everything, but it had no space, sonically, it was pretty flat. Mix wasn't like super bad, but I would go back and see if some things couldn't be opened up. Kick could use more thump, bass more hump and this would get the song out of a slump. I am trying to be Dr. Suess
Nothing bad, just seems you could do a little more to get some of the instruments to come out a bit more. Let's see what others have to say. I consider myself a newb and not the best for reference for feedback.
OK, dude, much better. Now let's see if we can dial it in a bit. OK, need the bass drum to thump more (try some compression to raise it up), Bring your bass up to give more bottom but start to slope off around I would say 150, experiment, but it was starting to rumble a bit.
I think this is becoming much better. Guitar becomes repetitive, but if you are going to add something over top of that, then it makes sense.
I don't like how much the snare drum pokes out at you, but it does sound nice and punchy and has some good dynamics. Everything else is almost there, as has been mentioned the bass frequencies in the mix are a bit unclear at times as well, there could be more clarity down there but overall not bad.
Real tight playing. I liked the energy and the way the song moved.
The bass has a real low end problem. Way too rumbly.
Guitars sound OK. I might like a little more low end to them. But in general I thought they were pretty good.
Just get the low end under control.
