H
Hi_Flyer
OK, so my band has an upright bass, which first of all seems (at least to me) to be a rather hard instrument to record/mix/play, and on top of that my bass player doesn't have the best technique... So basically my problem is that when I'm trying to mix his bass, I'll end up getting a few notes that jump way out in volume, for example the G fretted on the low E string. How can I tame this and even everything out? What do you call it when that happens? Is that what is referred to as the instruments "fundamental tone" or something like that?
Typically I have been recording on cassette multi-track machines (Tascam 424 and Tascam 688) and transferring to n-Track to mix. Part of the problem is that the tracks don't sound great to begin with, and I think thats partially due to the fact that a cassette format just won't capture the low end. So to compensate I use compression & EQ plug-ins, as well as a plug-in called Baxxpander to boost the lows. It works OK, but I tend to end up with the problem described above...
Keep in mind I'm not mixing for any serious projects, I mix mainly song sketches and recordings of shows, but I still want to learn better techniques...
And I guess the appropriate follow-up question is what can I do to get a better sound to start with? It seems like I'm just not capturing the low frequencies, so would a DI box help? What about a cheap preamp?
sorry for long post!!
