R
Reburon
So as a birthday present I was bought 2 mics(1 Samson Meteor condenser, and a Shure SM57 dynamic mic). I planned to use the dynamic to be behind the piano, and the condenser to be just in front of my face, to sing whilst playing.
Using Audition, I wanted to test the Meteor and the quality is great. However, whilst recording and playing and singing the piano had a tendency to cause clipping in the recording, which ruined the recording(I know you can go through a number of processes to help reduce the clipping, but I don't want it to happen in the first place). I understand it's a condenser(I may have made a slight mistake when it came to buying) and will pick up background noise, but I'm running out of ideas to stop the clipping.
If there was some way to block the back of the mic so it only(or mostly) picks up my voice?
I know its a big ask, but I can't send the stuff back or anything, so I just need an idea on what to do.
To summarise:
I want to record songs with 2 mics - A Samson Meteor condenser for vocals and a Shure SM57 dynamic for the piano/other acoustic instruments.
While singing AND playing, the Meteor picks up a lot of piano and causes clipping sometimes.
I want to stop the clipping, and have as little piano from the Meteor as possible.
Can you block the 'unused' sides of the Meteor(with a thick fabric or something) to reduce the amount of piano it picks up?
All of this is in a living room. Laminate floor. I know hard surfaces cause vibrations to bounce, and it could be a culprit. But there's nothing I can do, other than put down some blankets and rugs on the floor.
NOTE:
I haven't' got the cable for the Shure yet(it's on order), so anything you'd like me to do, I can't do until I get the cable.
Also, I'm an idiot with this stuff, don't use all this vocabulary that I don't understand, thanks.
Thank you, any replies are appreciated.
To summarise:
NOTE:
