M
musicmaker
Hi, my VS-880EX original internal hardisk was damage recently and I am try to replace it with a zip drive. When I connect my zip to the VS880EX SCSI port and swict on the VS later, the VS is just swicthed on and off immediately, the LCD display is just flashing and the VS will off automatically. Ok, even ocasionally I sucessfully swicth on the power of the VS with the Zip connected, the VS will stuck at the 'Scanning Drive' process, I try to wait for it to response, but it will never but still remain in 'Scanning Drive' process (still scanning SC1), and I finally have to kill the power and try again, but with the same result. ok, if I remove the SCSI cable from the VS while during the 'scaning drive' process, the VS will response immediately and proceed to scanning from SC1....SC7.....setup effect....everything will seem normal, finally it show 'No drive', this is normal since I have remove the internal IDE and there is no any drive connect to the VS.
What the user manual stated is ASSUME the VS can reach the play mode, because unless the VS reach the play mode only you can press the 'SYSTEM' button to select which external drive you want to initialize rite? But I just get stuck before what the manual stated.
Anyone please help me to solve this problem thank you!
wai
wai
Good luck.
