Nick The Man
lol im sure many people have used it
im just not really into triggers.. didnt mean to offend anyone
Nick The Man said:lol im sure many people have used it
im just not really into triggers.. didnt mean to offend anyone![]()
NL5 said:Although I understand your point, because I just like to plug an LP into a Marshall and call it good..........
jonnyc said:If you think it's cheating to replace or enhance drum sounds, then there are hundreds and hundreds of platinum records that people have "cheated" on.
RedStone said:I think your kick sounds fine. It has a lot of punch (which can be good or bad depending on the style), and maybe needs a low shelf to help the bottom end (esp circa 61hz). also consider a little dip around 250hz (as much as needed) to help boxiness, and use compression to change the ambiance of the kick
So here's what you can do to help that kick stick out of the mix once you are happy with the way it sounds:
High Pass EVERYTHING that doesn't need frequencies below 100hz ... and try to get away with as much of a HP as possible without thinning things out. It's a tricky compromise that takes a lot of practice (I know I'm not there yet) you can also Buss the bass guitar and the kick to a new buss (post FX) and throw a limiter on them - lower the threshold until they feel like they are locked together. Use the new buss as your low end to the track.
You may find that using a limiter on the kick itself and adjusting both the threshold and the "out" ceiling might work better than compression for fixing inconsistent foot. Just make sure there isn't too much gain reduction happening or you will flatten the kick completely.
OR
you may need to duck the bass - which is a GIANT workaround in Vegas ... but stupidly easy to do in reaper ... in Vegas, you'll need Gpan and a side chain enabled compressor. There are tutorials around on how to do it so I won't write it all out again
hope that helps a bit
ez_willis said:Hello??? Anyone going to ask what kind of mic and where it's placed, or did I miss that somewhere?
The best thing I ever did for my kick sound was upgrade from an atm25 to a Shure Beta52.
Sorry, cock-gobbler.jonnyc said:Yes you missed it, fucking tard.
Nick The Man said:god no matter what i do the kick gets buried ... when i eq it i must be doing something wrong??? what do you do to make the kick stick out?
NTK88 said:Aww I cannot use drumagog![]()
I have aducacity, sound forge 8 and adobe and it doesnt work in adobe.
Will it work in the other 2?
thajeremy said:yes it does work in Adobe....I only use Adobe Audition 1.5 and I use Drumagog....
