TheRealWaldo
Read your own post and tell me why you're wrong.
Why would there be size difference if the type of music doesn't effect the encode?
Other quotes directly from the same site you are quoting:
and
Just so you know, I've written a few audio codecs in my time. Lossless DOES mean a loss of DATA, which, in music, is a difference in the WAVEFORM, which DOES, even if you think you CANNOT HEAR IT, affect the SOUND QUALITY.
There is no alternative but to LEARN exactly what an MP3 encoder does, as apposed to reading other peoples 'recomendations' and adjusting your settings appropriately. Reading somebodies comment on the spectral difference between an encoded and the original sound means absolutely nothing unless you KNOW what the data means. And in every single test case they have, I see an audible difference!
Otherwise you will have alot of be-wildered people (as above) stating that it didn't work for them, and it sounds awful, and they'll blame it on the product (Or site in this case) you are trying to promote!
If you're going to make a huge claim, and speak of it publicly, you better be prepared to back it up, or be called a fibber.
Nothing against ya Nick, but don't try to 'wow' people with untruths.
W.
If you're into really loud and busy music, like some metal collections, your album averages could be around 200kbit/s. If you're into classical music, your album average may be 160kbit/s. To learn more why this size difference, read here.
. I am aware these do not represent the music you will be encoding, and therefore they are only used in the restricted, correct way:
and
no quantitative comparison, such as, for example, measuring and quantisizing the amount of deviation from the test signal at certain frequencies. Such deviation will differ with every different piece of music you encode, so there is no use for such tests.
W.
