Every thing everybody else said here is the right thing to say.
I'm going to go against my own advice here and give you a basic setting but dont take it as a preset. This is no more then a general starting point and should change acording to need -style - singer - Tempo - wanted effect.
Start by asking why are you insisting to use compression?
Remember that any processing of any kind tends to change the natural color of your track as well as potentialy damage it. You are going through another curcit and have to gain stage again and be carefull not to overcompress and...and...and.....
Are you sure of the need to track with compression?
Vocals - start off with a 3-5ms attack time and a 1/2-1 sec release time. Ratio - start with a 3:1 and set the Threshold to reduce the gain by 2-6dB at the peaks only. Depending on the above you might need to make the release longer to 2 secs acording to tempo or style. You might need a higer ratio like 7:1
again depending........
In practice I ask the singer to back up a bit during very loud parts
and when I track with a compressor, I make sure it barely goes into action if at all. It's more of a security issue.
I aim for the compressor to hardly go into action and if it does then the reduction at very loud parts should be around 2-4dB.
If the vocals are understandable and they sound good with no
compression problems like pumping or breathing - exaggerated sibilance - dull sound - added unwanted noise - losing the natural sound of the vocals - lose of dynamics, I know am ok.
Compression is at its best when you cant hear it !.
I cant remember were but I read a story of a engineer that claimed his compressor was doing a great job on the track untill somebody pointed out to him that it wasnt pluged in............
Embaressing as that is, it still holds the truth.
Good Luck...your going to need it
