Ryan, if there is a place that rents PAs in your area, try renting a small system or two to see what they can do. This will give you an idea of how much juice you need. Then start shopping.
Also for practice in a small space, placing your speakers will make a big difference in how well you can hear it.
Here is a link to a thread by someone practicing in a garage, some problems they had, and some suggestions.
https://homerecording.com/bbs/showthread.php?t=142117&highlight=speaker
Soundbyte said:
It's important to understand that impedance is affected by frequency, and that impedance ratings are usually given for a specific frequency. During playback of a fullrange audio signal into a 2ohm load, there will be instances where speaker impedance will drop well below 2 ohms. When driving multiple fullrange cabinets with a single amp at high power levels this could be a problem.
Yes, but it's not a linear function. There will be peaks and dips across the range of the cabinet. Each driver in the cabinet has it's own curve where it goes above and below it's nominal impedance. The overall curve therefore has peaks and dips. The box design even makes a difference.
Soundbyte said:
It's not as much of a problem for bi-amped or tri-amped systems since each amp is not driving a fullrange signal into a low impedance. I have a 3-way system with 2400watts/2ohm into the bottoms 1200watts/4ohm into the mids and 500watts/8ohm into the horns. It will run all day long at high SPL's without any trouble.
Each bandpass, lows, mids, and highs, will have points where the impedance drops below nominal. The actual power being put into that 2 ohm load is the issue. An amp might handle a 2 ohm load at half power all day, but start to choke at full power after awhile.
Biamping or triamping with an active crossover lets you use each amp and driver more efficiently, and generally with better sound quality vs. the passive xover, that's all. Sub amps work harder because they need to put out much more average power to balance with the mids and highs.
Your sub amp can handle two ohms all day long at full power because it can, not because it is only driving one bandpass.
