How much hard drive space for Cakewalk Sonar?
  • Thread starter Thread starter Shinobi
Shinobi
I'm thinking of buying this program, but I was wondering how big one's hard drive has to be to starting working with songs. 100gig drive? Thanks.
Shinobi,
> I'm thinking of buying this program, but I was wondering how big one's hard drive has to be to starting working with songs. 100gig drive? <
The Sonar program files are not that large, but audio data you record as Wave files requires 5 MB per running minute per mono track (10 MB / minute for stereo). A 20 GB drive is more than enough to do several CDs worth of music, but these days a 40 GB drive costs hardly any more than a 20, and so makes more sense to buy.
--Ethan
You should have two hard drives in your system; One for OS and Apps, one for audio. The first can be any size. I have a 40GB drive, 5400RPM ATA/100. Most of it isn't in use, as the OS and Apps occupy less than 5GB of space so far, but this drive cost me less than $100.
My second drive, the audio drive, is also a 40GB drive. It is a faster drive, as is recommended, at 7200RPM. It is also ATA/100. That is less important, however, as the rotational speed. You should have at least ATA/66 and 7200RPM. Also, typically you install both drives on one controller. If this is to be the case, make absolutely sure that both are at least ATA/66. The controller always defaults to the speed of the lesser drive in this configuration.
That said, I typically record 2-3 hours of my band's practice sessions per week, and can record like this for weeks before filling the drive. This gives me time in between to find points of interest within each practice and extract them...then archive them to the first drive with all of it's free space, or to my server...then clean up the audio drive.
That also said, 100GB is very excessive. By human nature, you are bound to put off cleanup until you have some unGodly amount of audio recorded. That would be a huge undertaking!
Thank You
Thank You both for your input. I do have enough hard drive space,so I'll hold off on buying that 100gig hard drive.
Thanks Again,
"Happy" Shinobi
Are you running two hard drives now?
Are both hard drives on the primary controller and both at least ATA/66?
I'm not trying to help you spend money, but I am trying to help you have a good performing systems. Don't try to get by with one drive, because you will have random dropouts, and you will be very limited on how many tracks you can record in one song. Also, the audo drive should be at least 7200RPM, for the same reasons. You have a better chance of getting by with an audio drive of 5400RPM than you do with only one hard drive, but to get the most out of your CPU you are running now, 7200 is what Cakewalk recommends.
If both drives are on one controller, or the Audio drive is on the same controller with a CDRom, then it's throughput will be decreased to the equivalent of the slower drive.
Only audio should be written to the 'audio' drive.
RE:My hard drives and specs...
I have a 5400rpm Western Digital for my primary thats around 1.6 gig, really small i know, my secondary is a 5400rpm Western Digital 10 gig. Plus I have more happy space across my network, but I'll tell ya... Someone gave me, as a early B-day gift Calkwalk Sonar!
I made a song with just two tracks so far and it's working great! I'm just doing some acoutic guitar stuff for now, but I want to get back into all my synth stuff as well. I have a small keyboard controller with a old Kawai K1m module and a really...really old, nice EX-800 module that is the same as a Korg Poly 800, If anyone here remembers that. LOL :)) I used to be into the MIDI stuff a lot.
I am awestruck about the clarity of recording on the computer, I mean..I only have a 4-track Tascam Porta-3, there nothing wrong with that I know, but.... Ok I'll stop rambling now. Thanks again for your input, very helpful and kind indeed.
"Happy" Shinobi
TNT- Thanks for the enlightenment regarding hdd controller setups. I'm currently throwing together a new system and had been wondering which way would be best. Now I know. I'm running a pair of 7200 rpm ATA 100 hdd and Yamaha UDMA 33 cd-rw. I had them hooked up with the hdds on each master, but will reconfigure them both to the primary before the next session.
Re: RE:My hard drives and specs...
Shinobi said:
I have a 5400rpm Western Digital for my primary thats around 1.6 gig, really small i know, my secondary is a 5400rpm Western Digital 10 gig. Plus I have more happy space across my network, but I'll tell ya... Someone gave me, as a early B-day gift Calkwalk Sonar! .....
Believe me, I know the thrill. I first got into Cakewalk with Version 2 about 17 or 18 years ago, with a Casio keyboard and later a Roland MT32 sound module. I have to get back into this stuff more now. I have been recording audio of and on since Pro Audio v5 and use Sonar v1 now, and here comes Sonar v2! I've done more in the last 2 years with audio, though. From Pro Audio v5 and earlier I mostly recorded and programmed midi for fun.
I have a Kawai K3, a Radio Shack Concertone keyboard, a Roland GR1, and still the Roland MT32...and I have from way back when, a Digital Research MX8 Midi patch bay to bring it all together. I still have alot to learn about Sonar and it's plugins, though, so I haven't got the midi planned and routed yet.... soon, I hope...
Tom Kemp
Re: both drives on one controller
No problem, these posts have helped me plenty of times, so I give back when I can! You'll see a huge improvement when you reconfigure....
conflicting advise
For what it's worth, I've read another thread where suggestions are made to have each hdd configured as the master on each of the primary and secondary busses. TNT, I'm still going to go with your advise of matching them (running "like devices" on the same bus).
Well, I'm glad that you are going to follow my suggestions. Just to make you more sure, these recommendations actually come from a combination of my computer experience anybody at the cakewalk newsgroups...as well as all of the websites I know of that discuss this subject: Prorec.com, this one..Homerecording.com and others. It only makes sense. It is a fact that the IDE controller can only run at one setting, whether it be DMA/33, UDMA/66 or UDMA/100 (ATA/66, ATA/100). Therefore, if you mix two indifferent drives, it will drop to the highest setting of the drive with the lowest rating. Most CDRom's are DMA/33 at best. Therefore, if you place it with a hard drive that is rated ATA/100, it will only run like with the throughput of a DMA/33 drive....majorly crippling multitrack recording and playback.
You'll find that alot of people either purchase SCSI controllers and SCSI drives for their audio and Video data, or they'll purchase an add-on IDE controller, giving them the ability to run up to 8 drives in their systems, and the ability to isolate drives onto their own controller for the greatest throughput..
Tom Kemp
