W
warant1
I've read that if you're using an external controller/mixer paired with your DAW, you have to assign the channels from your DAW to your mixer.
What i'm assuming is happening is...
1. assign specified tracks to external mixer
2. arm tracks for recording
3. Plug monitors into external mixer
4. play the tracks and mix on your external mixer similiar to how you would live, listening to the overall mix thru the monitors? (this is where i'm lost....unless i'm lost earlier in the list then please let me know)
So for example, if I had 10 tracks recorded from a live event, and I imported them to my DAW (Reaper), then I could use my behringer x32 digital console connected via firewire to my computer, assign those ten tracks to ten faders on my mixer, press record, then press play and just mix?
and if that's the case, can I use the effects, eq, and dynamics on my mixer instead of adding all that in my DAW?
I'm new to recording, and I do mainly live events. But the compnay I work for is trying to get into recording so i'm trying to learn all this.
Thanks guys,
let me know if you need more info.
Thanks guys,
