how do you
  • Thread starter Thread starter deandreray
D
deandreray
when making vocals on cool edit what is the best wayto mix. dirty south vocals in clearing your s s s in the eq in what are some good verbs compressors
Ahh, step away from the mic (a bit), address mic at an acute slightly off axis angle
compressors, eq's, reverbs should be in there for your mixes.
as far as the SSSSSibilance, I'd suggest you get SPITFISH. Works wonders. Totally
I dunno too much on cool edit, but you need some type of desser plug-in for your s s s before/after you run an EQ. Someone answer me, in cool edit, could you bus with aux's? If you could I would bus the reverbs, and add compression and eq to the main track!
