*looks around for Monty to whack Kelly's head...*
I forgot the rest of your question, sorry. I'll overshoot on the EQ, just to see if whatever tones I don't like can be changed in the first place, and to see if I got the right tones to begin with.
For example: You can reduce @ 200Hz to decrease the muddiness in vocals/horns. So I'll reduce the shit out of a lead vocal and listen to it in the mix to see if that was really what was causing the muddiness, and to see if this will really screw the vocal quality. If it works, I'll go back and HALF the EQ setting, and listen to it again. If muddiness comes back, then I'll set the EQ between the prior settings. And if it still isn't right, I'll just "UNDO" a couple of times to my orignal "test" EQ, which solved the problem in the first place.
BTW: in this case, I'd use the 31-band as opposed to parametric because I might also want to mask some out-of-tune vocals. So I'll try reducing the 3000Hz range at the same time as the 200Hz, which saves having to tell CEP to do an EQ again.
