How do I share plug-in settings between sessions?
  • Thread starter Thread starter dsharrington
D
dsharrington
I have some 6 track live recordings. Each song is a different session. So basically all the plugin effects will be the same (compression, reverb, EQ, etc.) but I can't figure how to export those settings out of one session and import it into the next session. Can someone teach me how this is done or point me to a place that explains it?
you can save your settings as presets. or you could go the long way and import the session data from the one you want and copy/paste them
Using PT 9, Mix one song. Open song 2. Go to File>Import Session Data, Choose Song 1. Set "Import" options to "Plugin Assignments and Settings" ONLY (or whatever of the other 20 options you like), and assign them to the existing tracks.
Voila. :)
