mjbphotos
Moderator
I can see that 1 or both wires have come of the jack on my Epi Dot. What's the easiest way to get this rewired? Pull out the lead pickup?
Thanks, I've got 2 good sounding acoustics already!Or how do you feel about playing acoustic from here on out?![]()
No...the jack goes in from the inside...and you screw it down from the outside.
Loosen the nut on the thread of the jack
Tie some fishing gut or dental floss round the thread.
Take the nut off and leave it hang on the thread.
Push the jack into the body of the guitar.
Retrieve the jack using a bent coat hanger or similar
Resolder as required.
Pull the jack back into place using the floss.
Partially re-thread the nut,
Cut the floss off the thread.
Tighten the nut on the jack socket.
If the nut just turns on thread and wont tighten use a bent coat wire to stop the jack from turning.
If you need to drop the pots as well make sure you ties floss round each one and tie the strand together to save losing them in the body.
Five minutes.
I have an old quarter inch phono plug striped back to less than the diameter of the hole with the cable still attached that I use instead of floss but I do a load of them.
