M
mercyme
Actually, this is a bit of followup to the question I posted below.
Assuming I am going to at least START recording using my laptop's onboard soundcard (ESS Maestro 2E), what is the best way to hook up my dbx 286A mic preamp to it?
The output on the preamp is a 1/4" plug and the manual says that it can use either a balanced or unbalanced connection. The LINE IN on my soundcard is 1/8" mini-plug and I have no idea whether it is balanced or unbalanced, though I expect it is unbalanced (Is there some way I can determine this for sure?).
So, what is the best way to connect these two devices? Are cables made for such a connection or will I have to make one? Maybe just use a mini-plug adaptor on one end of an unbalanced cable with two 1/4" plugs?
Thank you very much for any help.
