how do i combine tracks on a 4 track recorder
  • Thread starter Thread starter quietasdust
Q
quietasdust
I have an old yamaha 4 track & i lost the manual, but i remember it saying that you can combine tracks so that in the end it's as if it's an 8 track recorder. For example, after having the first 3 tracks recorded separately i can then record all of them onto track four, leaving tracks 1-3 free again. How do i do this? What do i put the settings on?? Please help!!! thanks!
Try this link for the user manual
Try this link. I think you'll be able to find the user manual for your model.
http://www.yamaha.com/proaudio/products/manual_library.htm
FWIW, be aware that when you do this technique, which I've heard called "Ping-ponging", the first three tracks' sound can seriously degrade by the time you mix down. Even if you mix to a computer hard drive, it's still going to be 2nd generation.
I use an old Fostex 4-track and I quit trying to combine tracks on it. I used to do it, but my orginal three tracks would always get buried under hiss and the other "fresher" tracks. Don't mean to rain on your parade -- Just my 2 cents. Hopefully you'll have better luck with it than I did. Give it a try and see what you think.
You can bounce internally, but you might get better results bouncing externally (especially if you have access to a 1/4" reel-to-reel 2 track machine). You can also bounce to a VCR (see Dragon's article on this) What are you mixing the final result to?
If you don't have a R to R, do this: record on tracks 1,2 and 3. Record enable track 4, place tracks 1,2,3 in playback mode, and record 1,2,& 3 onto track 4. It takes a lot of trial and error to get a good bounce, but if you avoid overuse of EQ (they are usually pretty lousy on the cheapy units), it can be done.
Bob
Quietasdust,
Buffalo Bob's suggestion about doing an external bounce to a VCR might strange but it works pretty well. When I was still using my Tascam 414 I began doing that and found the sound didn't seem as badly degraded as when I did an internal bounce.
I considered buying a minidisc player/recorder to do the external bounces but I eventually bought a PC and began using that to record, so I can't say how well that would have worked.
