how do i assign sustain pedal to record in nuendo
  • Thread starter Thread starter stealingsilver
stealingsilver
Probably really simple but have not found how to do it
thanks
Hmm...haven't done this myself, but I think that when I use mine with my midi keyboard, it just out puts the midi notes as being effected by the sustain pedal, instead of outputting the notes as I actually played them. Does that make sense?
If yours doesn't do that...and I'm assuming it didn't record w/ the pedal by just recording a midi track if you're posting about it...
have you tried arming the track to write automation while you are recording? (W) ...again I haven't tried this, but that's the only thing I can think of at the moment.
Let me know if you find something that works!
Sustain pedal is MIDI controller #64. It's defined as a switch so when it's on, it sends value 127. And when it's off, it sends value 0.
Are you using the sustain pedal while recording your MIDI track? If you are, it is indeed odd that it doesn't get recorded. Make sure you don't have some sort of MIDI filtering going on in Nuendo (I am not familiar with it, but assume that it would have such feature). If you're attempting to draw in the controller data after the fact, all you have to do is select controller 64, and draw 127 for on, and 0 for off.
Another thing you might want to check is to make sure that when you press the sustain pedal it actually transmits MIDI.
Good luck.
