how can I finish my vocal booth to get a professional sound?
  • Thread starter Thread starter grn
grn
grn
I have a "vocal booth" with the following specs:
It's 4x6' and about 8 feet high. The floor has ben raised about 1 inch and filled in with sand, then plywood was placed over this. The walls are made of drywall and have 6 inches worth of regular insulation stuffed into a 3 inch area surrounding all walls except one wall (which is basically underground, but that has panelling instead of drywall). The door is cheap, I think hollow core, with thin plexiglass/plastic in the middle for a window.
My question is this. What kind of materials (cheap as possible) should I use to minimize the reflections/reverb in the room and make it sound professional? I'd also like to use this room for amps and maybe even test some acoustic guitar in there. Right now I have some cheap foam from bedding and a lot of extra carpet.
What can I do?! I was thinking Sheetblok on the walls/door, seal the door off, then add plywood over that, then add the bed foam over that. Lastly I would cut out a carpet to roll down over the floor, but not make it permanant. Any suggestions?
