Tizzo said:I'm an audio engineer who has been working a year or two now ...
bennychico11 said:whoa guys, careful bashing on the new guy....we don't want to scare him off too quickly.![]()
chessrock said:Cool. Where have you been working and what kind of training?
Tizzo said:I went to McNally Smith College of Music in St. Paul, Minnesota. I was an intern at Black Lodge Recording, then did a couple of gigs there and now am back in MN.
The Black Lodge is a cool place, Ed Rose is great to work with. All the other engineers are fun to work with too. They have a great live room for percussion and anything else you'd want a spacious sound for. As I was leaving they were remodeling their B-room to something much better than what it was.
Does anyone know of a place to post wav files as opposed to mp3s?
myspace is shitty, try this link: http://www.myspace.com/tamrec
I also think that if someone makes money engineering music/audio they are considered an audio engineer.
grn said:what's wrong with drum samples? I don't consider myself an engineer, just a musician... but sometimes I will write songs with drum samples on purpose.
aren't they also good for home studios that can't achieve great clarity with drums? hmm I will post some stuff in the mp3 mixing clinic soon.
I would think drum samples should work ok soundwise, but the problem is the mechanical sounding loops in drum machines. However, by using a real drum performance on an electronic kit to trigger the samples (provided you have very high quality samples) I think you should be able to get a convincing performance. For someone like me, a solo composer working in a small home studio, it's pretty tough to be able to use real drums. And although I've had some reasonable results using midi loops and samples, I still want to get more "feel" into the tracks. Which is why I'm building a compact e-drum set to trigger my sampler with (of course next will be the small matter of learning to play the thingwhat's wrong with drum samples? I don't consider myself an engineer, just a musician... but sometimes I will write songs with drum samples on purpose.
grn said:what's wrong with drum samples? I don't consider myself an engineer ...
grn said:I happen to think the NS kit is pretty good (especially since it's free)... http://www.naturalstudio.co.uk/ns_kit7.html - even if you don't have triggers, you can use a sequencer to program the drums and if you add a bit of cleverness, you can make it sound human - then mix that with real guitars and such.
