Q
qwerty12
Hi,
I have a basement 44 x 14 ft with 2 x 10 joists and subfloor above it. One half of the space has a 7 ft ceiling, the other half is crawl space with 6ft
ceiling. I would like to convert the 7ft ceiling half into a recording studio.
It has a 4 inch cement slab floor.
I would like advise please on what I should do about the cement slab floor. It is a radient heated cement floor. I have been thinking about two options;
1. Staining the cement and put an epoxy over top
2. Putting a wood floor overtop. Not sure how to do this and keep the radient heat floor so it will still efficiently heat the basement.
The walls are currently cement poured with wooden studs, pink insulation and vapour barrier over top. I have been thinking of two options for finishing the walls:
1. drywall
2. Wood panelling with tonge and groove pine.
What to do with the ceiling. Between the joists I have safe and sound insulation 12". I was thinking of strapping the joists with 1/2 wood strapping and drywall over it.
Do these options sound ok. I would like to prevent sound from getting through the ceiling. As the walls are cement poured and there are no windows in the basement and the basement is completely underground, I think my main consideration in keeping noise from getting out is properly insulating the ceiling and wall I will be putting up to the crawl space.
Some advise would be much appreciated. Thanks.
Tim
1. drywall
Tim
