Check this
Yeah im workn on my overdubs and adlibs. My boy
2Tone is givin me some pointers, check out his track. Sneaky project, Paper Part 2, Krazie Bone Collab
http://www.tightbeatz.com/download.php?fileid=48463
My Artist Page is
www.tightbeatz.com/GSpot_Soldier
This is some of the stuff i posted in tightbeatz.com in a thread i started
Here is the thread address
http://www.tightbeatz.com/forum/index.php?showtopic=37100
Or here is some stuff
I learned somethin cool though for echos.
Like you know how some "end words" will have an echo, like if you say
We dont Play play ay ay. Well some of you already know this, but it sounds tight if ya just say it like that, and lower your voice each time, like fade away, instead of editing it with an echo pluggin(vst, ect..)
Also when doing an overdub, you can say over the normal parts at moderate volume level, and at words you want to stress, say that part louder. It adds a different effect i have found.
Here is a scheme i followed while practicing, and it sounded good.
I did the Main vocal rift(flow, line, rhyme). Then flowed the same thing again for an overdub
Then I did the flow again but in a deeper more "airy" voice on another overdub.
Then did another kind of tone overdub.
That is 3 over dubs, 2 of a different tone.
I kept the first overdub in the center(no panning L or R) to give the natural chorus effect to the main flow.
And to the 2 different tone overdubs i did some EQ and added the chorus effect with a pluggin. And panned one left about 25% and the other RIGHT about 20%.
Also if you know how to use automated effect sends you can take one of the overdubs that is panned left or right and use a volume curve that starts low in volume so it seems as if you are far away, and bring up the volume when you reach a punchline, or end of a sentence you want to stress.
If you havent got far enough into your mixing to do automated effects and volume/panning, you can just do the volume trick i was talkin bout earlier..
Start out at low volume then slowly raise your voice toward the punch line for one of your "panned" overdubs.
Its up to you but in order for adlibs or overdubs that are "panned" to sound good in the mix, experiment with volume levels. Most of the time the overdubs will be of low volume, blending in. But i have heard some artist have them at "Main Flow" volume level.
I also suggest paying attention to music you listen to. You can learn alot. Listen to the volume changes and automated panning. Also if you know about EQ, how the overdubs are EQ'ed in the mix.
And if anyone is wonderin why the tracks i have posted this far dont have any of these effects, its cause i am low on time, and dont have a good place or equipment to record, im in Iraq at war my homies and homettes.
I will post some more shortly. Ima do some more experimentation and listening
and
IF you copy and paste the vocals, at the same time location, it will just boost the original.
Then for when the chorus comes in you can add 2 more overdubs and pan them so much left and right, till you have the right mix, for the chorus to have impact.
Or you can flow the main flow, then do the overdub, then add some chorus effect or what ever.
Adlibs, dont really know about those. Aint got to that yet. Ima do it of course..
To get a little echo effect on certain end Phrases, you can select and copy the phrase, and offset it a little after the original track, and add some effects to it.
Or if you have the echo effect that enables it to continue the echo past end of selection, that will work. I know Adobe Audition 1.5 has it.
Any body else got any preferences, please share your techniques
So bring on the ideas yall.
