hi-fi hi-hat
  • Thread starter Thread starter WEBCYAN
WEBCYAN
WEBCYAN
My hi hats sound too....low fi.
I have actually found the perfect git tones for what I want, but it is lacking crucial hi end that gives it that crisp sound. I know that the hi hats are the problem. When I EQ it it just sounds over proccessed.
Any way to fix this and have it sound more organic. I also have the cymbals panned a lil to the right with kick, snare, toms dead center.
WC... the 1st rule of recording: if it doesn't sound good in front of the mic, it's going to sound even worse AFTER the mic.
If your hi-hats are the problem then the solution is to change them..........
Bruce
Once again the man is right!!!
Nothing more real than that...
you can't make a wall sing, no matter how much EQ you use...
Peace.
PC
Re: Once again the man is right!!!
PowerCouple said:
...you can't make a wall sing, no matter how much EQ you use...
Peace.
PC
wellllll....if that isn't a bit of *sheltered* information. Take a walk thru the projects, and if you can't hear the walls *singing* for all the over-hyped bass EQ happnin', then bro, waz be yur name??
I love that!! I will use that!!!
You probably need a better mic and preamp. You cant add high end with EQ. You can only emphasize whats there and that is probably hiss.
