C
chessrock
Banned
I just picked up the Delta 1010LT, and I'm running in to some stumbling blocks. Audio is going in and coming out just fine. I plug the mic in to it, and I'm getting levels. I just can't record with it. Just about all of my software is giving me compatibility errors. example:
Soundforge: "The PCM In 1/2 Delta-1010LT recording device does not support one or more of the current format parameters (sample rate, number of channels, or bits per sample).
When I change the sample rate to 22,050 hz, then I don't get that error message any more . . . but I hit the record button and basically nothing happens. It says it's recording, but then when I hit the stop button, there's no data, and no recording time actually elapsed. Just about every program I use is doing the same thing (cubase, n-track, vegas, etc.)
I have an AMD Athlon (K7) processor, 650 Mhz, with 128 MB of ram. These more than meet the minimum requirements for the card . . . but I'm wondering if I need to have an Intel (?)
Any ideas as to where my problems might be?
Thanks!
Thanks!
