help
  • Thread starter Thread starter daveblue222
D
daveblue222
hi i have installed all the drivers correctly for my multimix, and everything seems cool. the problem i am having is setting it up correctly in cubase. i dont have monitors connected to th mixer, so I want to use my pc soundcard and speakers for monitoring and most importantly, playing back what i have recorded. i can manage to get a signal into cubase but only by switching between the master ASIO driver. can someone please help me with this
thanks
Actually I dont think you can use your computer for monitoring. I went out and bought an amp and some nearfields cause I was sick of using headphones. The Multimix is now your "Primary Audio Device." I think you have to use the monitoring outs available on the board. Good luck!
Thats not my link there by the way! Dont know where that came from!!
Well, you CAN monitor through the PC while the multimix is plugged in, but it can be a PITA. The only way to do it is to switch your playback device to your stock soundcard, but you'll be doing a lot of flipping back and forth between that and the multimix (between playback and recording).
I say keep it thru the board, either with headphones, monitors, or just plug the PC speakers into the headphone jack of the multimix. (you'll prolly have to buy a 1/4" to 1/8" adapter)
Amen to that.
I got a mutimix (it's only the usb 8) and really, it's best to just hook up your speakers and use it as your soundcard. I eventually got monitors, and I run everything that comes out of my computer from them.
