M
museic
Hi I posted this over at gearsluts, but haven't gotten any responses, so I thought I'd post it over here and maybe someone would chime in...
Could someone please give me a hand on how to properly wire up a 1/4" TRS --> (2x) XLR Y Insert Cable? Basically this cable:
Mogami 1/4" to XLR Split Insert Cable
I've been trying to do this from various posts of people but nobody has explained it well enough for me to get it.
I'm trying to build insert cables to connect my new ARt Pro VLA II to my Toft ATB 16...
The toft is Tip Send, Ring Return, Sleeve Earth.
The Comp is:
Input: pin 2 hot, pin 3 cold, pin 1 ground
Output: pin 2 hot, pin 3 cold, pin 1 ground
I have some Mogami 3106 Dual Channel Audio Cable, which I thought was going to solve my wiring problems, but I still can't figure it out.
Heres what I did.
TRS end...
twisted both ground wires (as this is multi channel cable) together and soldered to sleeve. Blue wire on send to tip. Clear wire on return to Ring. Leaving the other clear and blue wire on the send and return unused.
XLR Input...
Blue send to pin 2, ground on pin 1, clear unconnected
XLR Output...
Clear return to pin 2, ground to pin 1, blue unconnected
If someone could give me a hand here, I'll make a little tutorial with pics as I can't find one anywhere on the web for this!
Thanks!
The Comp is:
Heres what I did.
TRS end...
XLR Input...
XLR Output...
Thanks!
