J
jbonil1
Hi. I'm new at this and I believe i made a mistake somewhere in my daw configuration. Ok, I record my vocals via a shure sm58 that goes through an art tube preamp
http://www.americanmusical.com/item--i-ART-131--m-6_87_359_926--brand-19.html
since I read at tweakheadz the compression should be added to vocals before the mix with an external compressor
( http://tweakheadz.com/how_to_record_vocals.htm)
and because when I used my presonus inspire built in mic preamp the volume change was very big. What I mean is If I set the volume enough so I could hear it the limiter will shut me down and if I used a low volume I wouldnt hear it plus I've read vocals should be near 0dB. thus I connected the art preamp to the mic preamp of my presonus inspire interface.
http://www.americanmusical.com/item--i-PRS-INSPIRE.html
The problem is my vocals sound kinda electric not natural, I still have the same problem with the volume set up not able to set it to 0db and I get a lot of mutings on my vocal tracks. I set the art preamp input gain to 30( so i can hear it), the compressor threshold to -10db the slope in compression the speed to fast, normal phase, and output level to -3. I've played with it a lot and still don't get an optimal vocal. any suggestions? Thanks
The input to
The input to
