thebigcheese
"Hi, I'm in Delaware."
I was tracking down a weird resonance when running my McCarty into my Roadster and the source seems to be my pedal board, so I am trying to figure out how to get as close to the sound of no pedals as possible. Here is my signal chain - maybe someone has some pointers on how I might rearrange things.
Guitar -> Mogami Platinum 12' cable -> pedal board -> Mogami Platinum 12' cable -> Roadster
Pedal board (wired with George L's):
1. Fuzz Factory
2. Mastotron
3. Whammy DT
4. EP Booster (on, but set to no boost so it's just a buffer)
5. Polytune Mini
6. Dyna Comp (with true bypass)
7. Soundblox 2 Multiwave Distortion
8. Vortex Flanger (set to buffered bypass)
The Fuzz Factory is first because it gets cranky with anything before it. The next two just happen to fit well on the board in that order, otherwise I would probably do the EP Booster next. The EP is only meant as a buffer with a bit of a brightness boost. Everything else is pretty much just in the order it fit on my pedal board (well, and what made sense from an FX order standpoint). I have been experimenting with swapping the EP Booster and the Mastotron, but that doesn't seem to make any difference. I am trying to avoid buying a switching system, especially when everything on the board is or can be true bypass anyway. I feel like it must have something to do with all the cabling, but George L's are supposed to be high quality, so I don't know. What I am noticing is a bit less brightness and an ugly resonance that I can't EQ out on the amp somewhere in the upper mids (probably as a result of the treble roll-off). Any suggestions?
1. Fuzz Factory
2. Mastotron
3. Whammy DT
5. Polytune Mini
bedtime for me
