P
Papoola
Dear Specialists, tks already for being so kind in helping me.
I actually recorder 12 tracks on my Korg D 16 digital multitracks recorder.
Now I intend to mix it, gives general effects/compression and put it on a audio CD-R.
I have a PC that I would try to use. I have not a good audio cards because all the music made by me is played on hardware gears.
I have a Orb SCSI back up unit for the Korg but i doubt I can succesfully transfer tracks from it to the computer, or better said probably buying a audio card will get more flexibility, isn’t??
Question is: if I get a Terratec 24/96 with SPDIF IN (Korg has a SPDIF out), it is supposed that the signal will be transferred into the pc remaining in the digital domain, Is it correct ???
Would not it remain in the korgfile format ?? The korg multitrack give the possibility to export files in wav, that probably will be the solution !!
How will then manipulate the tracks inside the PC ??
Pushing the play on D 16 and record the result with a software sequencer ???
I imagine that after this i will be able to transfer it on a CD that will be playble on HIFI gears. Correct ???
