Help with Mixing in Acid Pro 4.0
  • Thread starter Thread starter bclochesy
B
bclochesy
Alright, my problem is how do you export a mixed down 5.1 surround sound file? It only lets me export each track but I want it all in one. I'm recording a demo for my band which is very heavy metalcore and when it's just in stereo mode, everything kind of clutters together and the mix is really shitty sounding. I can get everything to sound a lot better with surround sound mode but then I can't export it as one track so its useless to me. Any help would be appreciated.
I was also wondering about something else...
Alright, we have 1 guitarist, 1 bassist, a drummer, and a vocalist...
For the guitar I tried to duplicate it, and run one track in the left, and one in the right channel, to make it sound "heavier" and fuller...but my problem is...
Say I start a song out with only guitar coming from the left speaker, with the drums doing a build up deal, then the song kicks in so I turn both channels on, it seems to all clutter back into the middle of the mix and doesn't want to stay on the sides.
If that made any sense...
if all you did is duplicate the track you didn't really do anything except make your guitars louder.
You need to put some chorus, or a slight delay or pitch shifting on one of the tracks to obtain stereo separation...
ok...
Sorry...I really don't know much and I was really getting pissed off last night, when I found this site.
Sorry if I come off as being stupid.
You are going to have to learn how to pan it properly
mixing and recording 5.1 in acid pro
bclochesy said:
Alright, my problem is how do you export a mixed down 5.1 surround sound file? It only lets me export each track but I want it all in one. mixing down the tracks to their respective 5.1 channels doesn't improve the sound quality, it simply is part of the conversion process to eventaully burn all five mono channel onto a dvd if you have sonic foundry's 5.1 plugin. if you leave the song in 5.1( and without rendering to any other form) go to tools > burn track at once > close disc when done burning. acid will automatically burn in stereo, but your panning to the left,rightfront and back will remain exactly where you left them in the mix. it works great trust me sounds way better than changing to stereo or rendering to another file format. In regards to your other problem with doubling the guitar to make a heavier sound,reverb, delay or pitch shifting will only alter your sound they can't make it naturally fuller. the best solution is to play and record the tracks two different times. the slight variations between the two tracks ( such as different picking or strumming or an eq. adjustment) will make it sound like two guitarists playing the same riff rather than one track doubled.Also be sure to pan them to the hard left and right to get the fullest sound, maybe even double both of these tracks but put them closer to the center with a touch of reverb on the doubled tracks good luck!!!
How are you sopposed to pan is properly? I thought you just, say, put 50% on one side so you put the next track 50% on the other side.... is there something else to it?
