T
THC815
Hey guys, I came across this forum in my google searches, hoping I could get some help. I bought a last gen Maschine this past fall and it has never worked properly. I kinda ignored it for awhile, but now I want to start really using this thing. Pretty much the problem is my Maschine program won't give audio output 9 times out of 10. I've noticed that when I've opened Itunes before opening the program it causes the issue. Even after I close Itunes it still won't play audio, but if I restart my computer and never open Itunes it will work just fine. Also, the Machine works perfectly fine through Ableton, though its the only DAW I've tried it in. I have the audio drivers downloaded and it's setup correctly in my preferences based on what I've found through various searches. I would like it to be able to run by itself so I can practice with just my machine and its software, you really can't have much flow running it through Ableton.
I'm using Windows 7 and on a HP desktop thats a few years old (not sure the model info, will edit in once I figure it out).
Figured I'd start here, maybe make a post in the NI forum, but it never seems helpful.
