K
kajani01
Hi guys, i'm new to this so please bear with me.
I'm hoping to build a vocal booth in my shed at home so i can record clearer vocals for my music. The space i have to work with is about a single car garage space in a double car garage. The ground is paving and the walls of the shed are that thin tin nonsense.
I've been reading about how to go about this but it is faily confusing as i don't know the first thing about building/carpentry.
My plan so far is as follows:
build a 4ft by 6 ft by 7ft box with a corner missing (2 walls dont join together - meaning the floor looks kind of like a large simcard) for entry and exit. I dont think i can afford to build a door at this stage so a heavy curtain to cover the opening might have to do.
start with a heavy rug over the pavers
use ply wood (or chipboard over rockwool slab/or similar material) as a base
the walls and ceiling will be of timber construction frame with plaster board for the walls (2 layers on the outside and 1 layer on the inside. between these with be insulation (rockwool also)
to finish off, probably stick acoustic foam on all the walls and the ceiling.
My questions are:
will this be sufficient to get reasonable quality recordings (obviously not studio quality but clear and without so much resonence/echo)?
Is there any improvements that can be made to this?
Is the heavy curtain over the entry enough or is there another cheap way of building a door?
Is there anything i can do during construction to make sure the sound is clean (ie, using certain screws or glue or spacing between wall layers etc?)
Is there any changes that need to be made because of the structure of the shed (verrrry tinny/echo in there)?
can any improvement be made to the floor design, such as building it like the walls with insulation within the floor??
Any help would be appreciated...
thanks
My questions are:
thanks
