help with guitar rig/rig control in cubase
  • Thread starter Thread starter s0ze
s0ze
here's my set up:
-mac powerbook g4 running osx tiger
-guitar rig 2 w/ rig kontrol
-cubase se (I purchased se ver 1.0.7 with the intention of upgrading to sx as I get the cash)
here's the problem:
I run my guitar through rig kontrol 2 and from there the signal gets sent to my mac via usb. guitar rig works excellent when I use it by itself. This is not the case when I try to use it in cubase se. When I open an audio file and click the monitor button all that comes out is static and when I switch channels I get horibble latency. My input is set to rk2 through the devices menu but the direct monitoring button is greyed out, which the manaul says is caused by improper asio driver. These divers would probably solve all my problems but I have no Idea where to find them outside of NI's update center. does anyone know where I can find these drivers and which ones I should use without having to go through NI registration.(I upgraded from a guitar rig 1 cd that I purchased off of ebay and have been using keygenerators to install gr1 and then upgrade to gr2. so theres no way to register my copy.)
any help would be greatly appreciated
