help with file export with Sonar 6
Beeros
Hi everyone...
First of all, I use Sonar 6 producer edition.
I almost always choose the 16 Track Audio form when i start a project...
here's my problem : I records some tracks, adds effects, adds envelopes, etc and at some ramdom point ( let's say I create an volume envelope... ) I try to save my work, Sonar tells me about blablabla saving with others form of sounds like MIDI ...blablabla... weird cause I never import anything except wav....
And this is directly connected to the next problem :
When I try to export the file to WAV format, it tells me that the mix ( or the project ) contains some non-audio files. I just undo the last steps ( in this example it's the sound envelope ) and the problem is solved and it's now possible to export...
the problem occurs ramdomly... sometimes it's because I record another track, sometimes it's because I add an effect to the track.....
Can someone help me with that ???
IDK, just a thought:
I always "select all" and then "Bounce to track" the whole mix before exporting to WAV. That way I only export one complete mix audio track to WAV, not the whole project. (I solo the bounced track and then export as 16 bit.)
I think the process is Record > Mixdown > Export. You might be leaving out the mixdown?
Hi everyone...
Beeros,
Sounds like somehow you got some MIDI information in there. But yea, bouncing it down should take care of that
C/M
