B
braveheart
I have an EchoStar satellite dish. EchoStar claims that the sound quality is CD quality. I assume that this means that the digital signal is 16 bit and 44.1 KHz. My subscription service includes CD channels which plays music (only) of various genres.
I want to record some of this music directly from the EchoStar box on to my Sony TCD-D8 DAT deck.
On the back of the EchoStar box are (1) left and right channel RCA phono plugs and (2) one squarish audio-out plug.
Several questions regarding this set up:
A - Regarding the analog signal:
(1) I assume that the stereo signal coming from the RCA phono plug on the EchoStar box is an analog signal? Is this correct?
(2) If the signal coming from the two RCA plugs is analog, then does this mean that somewhere within the EchoStar box there is an analog-to-digital converter?
(3) I have used a phono-plug to mini-plug cable to connect the RCA audio-out on the back of the box to the mini-plug line-in on my D8, set the sampling rate to 44.1 KHz, and set the recording level to automatic. Any other considerations that I should be aware of? (By the way, to my untrained ear, this set-up seems to work fine.)
B - Regarding the digital signal:
(1) Is that squarish plug on the back of the EchoStar box a Toslink plug? It does say something like: "optical-out" I do use this plug to connect the EchoStar audio to my home theater reciever "optical-in". I just want to understand if that plug is what DAT heads seem to refer to as a Toslink plug. Yes..? or No..?
(2) If that plug is a Toslink plug, can I then assume that the signal is a digital signal?
(3) If the signal is a digital signal, can I assume that the signal coming from the Toslink plug is 16 bit and 44.1 KHz?
(4) My D8 DAT will only record at 32 Khz, 44.1 KHz, or 48 KHz. If the signal from the EchoStar Toslink plug is not one of those frequencies - what do I do?
(5) Is it important that I set the recording sample rate on my D8 to correspond to the sample rate of the incoming digital signal?
Thanks in advance,
Earl
Thanks in advance,
Earl
