L
leecea
I just bought a used 414 Mk2.
I tried making some test recordings by following the "direct recording" section of the manual and I have noticed that Ch 1 seems to overpower everything else.
During recording I adjust the faders so that each channel is peaking at the same level, but during playback Chs 2-4 play back with significantly reduced levels but Ch 1 plays back with its meter showing the same levels as during recording. When I listen to the result, Ch 1 dominates the sound. I've tried a few different things and get the same effect each time.
Can anyone suggest what I'm doing wrong or have I been sold a defective unit?
In case it matters, I'm using some Quantegy 472 C-30 tapes that were sent along with the unit.
Thanks.
Thanks.
